Tuner Genius XL Introduction Video
A quick tour of the features of the Tuner Genius XL.
$1,999.00 - $2,399.00 $1,999.00 - $2,399.00
SO2R Model is currently unavailable and will not add to cart.
An advanced engineering approach to tuner development has resulted in truly highest quality hardware and software solutions.
Our software developers have extended the tuner with new functions, and completed integration with Antenna Genius, forming a single system. Very easy to use, uncompromisingly functional, the integration of TGXL into the Genius platform extends both functions as well as protection systems.
Once setup, TGXL will remember individual settings for each frequency change and will go to bypass if your antenna is in a segment with good SWR.
1×3 version
SO2R Version
The First SO2R Tuner to Hit the Waves
Introducing the Tuner Genius XL. The first SO2R Tuner in the amateur market. Also, soon to be available in a 1×3 version. The Tuner Genius XL is a full frequency coverage tuner from 1.8 MHz to 54 MHz with the ability to tune up to 10:1 SWR.
With the ability to handle up to 2000W ICAS of power, the Tuner Genius XL is built to high quality “broadcast industry” commercial standards.
Ease of Operation
All Tuner Genius XL functions can be controlled either from the front panel of the tuner or using a Windows computer software application. This allows the Tuner Genius XL to be placed off your desktop if needed. High precision “peak responding” RF power and SWR meter displays are also provided, therefore, you no longer need a separate Watt/SWR meter device in your shack.
Fully Integrated
The Tuner Genius XL is fully integrated with the Power Genius XL RF amplifier and ALL FLEX-6000 or FLEX-8000 Series HF transceivers. All FlexRadio products utilize a standard LAN communications protocol and with the published API you can write your own applications for your tuner setup. Though you can use your Tuner Genius XL with any modern HF radio on the market today, when used in conjunction with a Power Genius XL and a FLEX-8600 transceiver, you gain full SO2R (single operator, 2 radio) operation for your station including support for multiFLEX™ operation. Frustration-free contesting goes hand-in-hand with reduced station costs and ease of set-up.
terst
Dave, WO2X takes you on a tour of the Tuner Genius XL quick start overview.
QSO Today Expo from Match 2021 - W4AX introduces the SO2R Tuner Genius XL.
