SmartSDR 101
Mike touches on some key SmartSDR elements, the software, where to download the software, where the manuals are, and some basic functions within SmartSDR.
MSRP: $4,399.00 $4,399.00
The FLEX-6600 offers the ultimate performance direct sampling SDR technology and the best value for the serious HF/6m operator.
The FLEX-6600 model is designed for the Ham who wants to operate the radio exclusively as a server from PC, laptop, Maestro, Mac, or iOS clients — whether local or remote. Both models share the same game-changing band awareness, industry-leading phase noise performance/ receiver dynamic range, and brick wall filters to give you the advantage in the most competitive DXing or contesting activities while maximizing your fun in casual operations. With a PC, laptop, or Mac client, you can utilize up to four 14 MHz spectrum/waterfall displays and independent band/mode receivers to revolutionize your view of the bands, especially on digital modes. Antenna Tuner is included.
Contest grade filters, ultra-low spurious emissions, and the ability to operate full duplex cross band on two antennas let you transmit on one band while receiving on another — no external equipment required. Even switch to synchronous diversity reception when needed to help you pick out the weak ones in the midst of QRM. By adding FlexRadio’s new Power Genius XL™ LDMOS solid-state amplifier a complete legal limit, all mode SO2R station is now practical with one radio, one amp and only three interconnect cables — half the cost and none of the complexity.
FlexRadio’s industry-leading SmartSDR™ software offers compatibility across the entire FLEX-6000 Signature Series family to deliver continuous leveraged software enhancement. And you can use the latest SmartLink™ technology to access your radio virtually anywhere from any SmartSDR compatible client with only a login and password — even your iPhone.
About the Flex 6400 and a single Spectral Capture Unit.
How to adjust and set up the microphones - for the new Flex user.
An overview of FRStack by Mark W3II.
A video about SmartSDR and some of the basic interfacing that it can do.
Tim walks through optimizing reception for the Flex 6000.
Welcome to SmartControl for your Flex 6000 series radio.
Mike goes through one of the most reliable ways to network your Flex 6000 series radio.
The USB ports on the back of the radio are used to control external RS232 devices and non RS232 devices.
Mike does an overview of SmartSDR and Global Profiles - radio memory.
