>FLEX-6700
FLEX-67002019-03-14T23:07:01-04:00
Compare Products
Buy Now
Contact Us
FLEX-6700 HF/50MHz Transceiver for the most demanding amateur
The Ultimate On-Air Experience
Total Flexibility
With SmartLink remote*, just turn it on and play radio from anywhere.
  • Dirt Simple Remote
  • Plug and Play
  • Built in Wi-fi and Ethernet
  • Truly Wireless Operation**
Maximum Performance
  • SO2R in one radio
  • 116db RMDR
  • Continuous MARS/CAP TX Coverage
  • 0.02ppm OCXO
  • 8 digital audio streams and 4 IQ streams
Flex-6700 Specifications
 Receiver
  • Receiver Architecture: Direct Digital Sampling
  • Spectral Capture Units: Two (2)
  • Maximum Slice Receivers: Eight (8)
  • Maximum High Resolution Spectrum Displays: Eight (8)
  • Maximum Panadapter Width: 14 MHz
  • ADC Resolution: 16-bits
  • ADC Sampling Rate: 245.76 Msps
  • Wideband Frequency Coverage: 30 kHz – 72 MHz; 135 – 165 MHz
  • DAX IQ Channels / Bandwidth Per Channel: Four (4) @ 24 kHz – 192 kHz
  • DAX Audio Channels: Eight (8)
  • Amateur Band Preselector Coverage: 160m – 6m (except 60m)
  • Preamplifiers / Attenuators: -10 to +40 dB
  • Spurious and Image Rejection Ratio: 100 dB or better
  • External Powered Speaker Output Impedance Level: 600 Ohm Stereo Unbalanced
 Mechanical
  • Height: 4″ (10.2 cm) with feet; 3.5″ (8.9 cm) without feet attached
  • Width: 13″ (33 cm)
  • Depth: 12″ (30.5 cm) or 13″ (33.04 cm) with front handles
  • Weight: Approximately 13 lbs. / 5.9 kgs
  • Operating Temperature: 0 to +50 degrees C; +32 to +122 degrees F
 Transmitter
  • Transmitter Architecture: Direct Digital Up-conversion
  • TX DAC Resolution: 16-bits
  • TX DAC Sampling Rate: 491.52 Msps
  • RF Output Power: 1-100W nominal SSB, CW, FM, RTTY, Digital; 1-25W nominal AM
  • Amateur Band Coverage at Rated Power Output: 160m – 6m
  • Low Pass PA Filter Bands: 1.8 MHz – 30 MHz continuous, 50 MHz – 54 MHz
  • Transverter IF Output Power: +0 dBm Typical; +15dBm max (+7 dBm, 2m)
  • Transverter IF Frequency Coverage: 100 kHz – 72 MHz; 135 MHz – 165 MHz
  • Modulation System: Digital Low Power at Carrier Frequency
  • Maximum FM Deviation: ±5 kHz
  • DAX Transmit Channel: Yes
  • Carrier / Unwanted Sideband Suppression: <-80 dBc typ / <-80 dBc typ
  • Spurious Emissions 1.8 – 50 MHz Amateur Bands: <-55 dBc; -65 dBc 6m
  • Transmit Bandwidth: Default 100-2900 Hz (Variable 50-10000 Hz)
  • Microphone Connectors: Unbalanced 8-pin Foster, Balanced XLR/TRS
  • Microphone Impedance: 600 Ohms Nominal (200-10kΩ)
 Antenna
  • Matching Range 80m – 10m: 8.3 Ohms – 300 Ohms
  • Matching Range 160 and 6m: 16.7 Ohms – 150 Ohms
 Electrical
  • Power Supply Requirements: +13.8V DC nominal ±15%
  • Current Drain (Receive/Transmit Max): 3A / 23A @ 13.8V
 General
  • 2U, 19inch (48.26 cm) Rack Mounting Kit
  • Front Handle Kit (adds 1 inch/2.5 cm to total depth
  • USB 2.0 Ports (peripheral control): Two (2)
  • Master Clock Frequency: 983.04 MHz
  • Master Clock Phase Noise: -147 dBc@ 10 kHz; -152 dBc@ 100 kHz
  • 10 MHz Reference Clock Stability: 0.02ppm OCXO
  • Emission Modes: USB, LSB, CW, RTTY2, AM, Synchronous AM, FM, NFM, DFM
  • Frequency Resolution: 1 Hz min.
  • Antenna Connectors: SO-239×2, BNCx2, XVTRx1
  • Antenna Impedance (w/o tuner): 50 Ohm Unbalanced
  • GPSDO with Rear Panel 10 MHz Reference Output
  • GPSDO Frequency Stability (GPS locked):1 5 x 10 (-12) over 24 hours
6700Back
Build Your Station.
Maestro Front View
Maestro Console
PGXL2
Power Genius XL Amplifier
Visit our Learning Center
Need help with our products, software or services? Start by visiting our learning center. Once there, you can download data sheets, quick start guides, installation manuals and watch video tutorials.
Learning Center
AppIcons_WEB_SDR_NoShadow
AppIcons_WEB_PG_no-shadow
AppIcons_WEB_DAX_NoShadow
AppIcons_WEB_CAT_NoShadow
*SmartLink Remote Requires SmartSDR V2.x License. Requires internet connection. **Requires customer supplied battery.
Specifications subject to change without notice. 1Requires optional GPSDO module 2Requires 3rd party software.
Footer Content
Company
About
Contact Us
Events
Careers
