FLEX-8600
FHM-3 Hand Mic
DC Power Cable
Ethernet Cable
Quick Start Guide
GNNS/GPS Antenna
All Radios
Ships in ~4 weeks after placing your order
FLEX-8600 Signature Series SDR Transceiver
MSRP: $4,899.00 $4,899.00
The FLEX-8600 offers the ultimate performance direct sampling SDR technology and the best value for the serious HF/6m operator.
Supporting Adaptive Predistortion
The FLEX-8600 model is designed for the Ham who wants to operate the radio exclusively as a server from PC, laptop, Maestro, Mac* or iOS* clients – whether local or remote.
Both models share the same game-changing band awareness, industry-leading phase noise performance / receiver dynamic range, and brick wall filters to give you the advantage in the most competitive DXing or contesting activities while maximizing your fun in casual operations.
With a PC, laptop, or Mac client you can utilize up to four 14 MHz spectrum/waterfall displays and independent receivers to revolutionize your view of the bands, especially on digital modes. Antenna Tuner is included.
Contest grade filters, ultra-low spurious emissions, and the ability to operate full duplex cross band on two antennas let you transmit on one band while receiving on another – no external equipment required. Even switch to synchronous diversity reception when needed to help you pick out the weak ones in the midst of QRM.
By adding FlexRadio’s Power Genius XL LDMOS solid-state amplifier, a complete legal limit, all-mode SO2R station is now practical with one radio, one amp and only three interconnect cables–half the cost and none of the complexity.
FlexRadio’s industry-leading SmartSDRTM software offers compatibility across the entire FLEX-8000 Signature Series family to deliver continuous leveraged software enhancement. And you can use the latest SmartLinkTM technology to access your radio virtually anywhere from any SmartSDR compatible client with only a login and password – even your iPhone. Radios are licensed for SmartSDR Basic.
* Mac OSX SmartSDR and iOS SmartSDR clients are provided by third-party vendors
