2000 Watts from
2000 Miles Away
Just turn it on and operate from anywhere*
- Fully integrates with FlexRadio’s SmartLink remote
- All controls and meters, available anywhere
- Ethernet Connected
Frustration Free Contesting
Dramatically reduce cost and complexity
- SO2R with one amp
- Plug and Play SO2R
- No complex cabling
- Minimum 60dB port-to-port isolation
Compatible with Any Modern Transceiver
Plug & Play Power
Complete integration with FLEX-6000 Series
- Amplifier/FLEX-6×00 Meter Integration
- Automatic band switching
- Full ICAS duty cycle on all modes including RTTY & FT8
- Ultra Fast High SWR Protection
- Compatible with any modern transceiver
- 4O3A Inside
Downloads for your PGXL
Full Specifications
PA
- 160 – 6M Ham Bands
- RF Power Output: 1500W (ICAS), 2000W Capable
- Exciter Drive Level: 50W Typical (US version)
- Transistors: MRF-1K50H x 2
- Exciter Inputs**: SO-239 x 2
- Antenna Outputs: SO-239 x 2
- Antenna Impedance: 50 Ohm Unbalanced
- Cooling: Thermally Controlled Fans
Mechanical
- Dimensions: 5.75”H x 14”W x 19.5”D (14.6 x 35.6 x 49.5 cm)
- With Feet: 6.25”H x 14”W x 20”D (15.9 x 35.6 x 50.7 cm)
- Weight: 37.4 lbs (17kg)
- Operating Temp: -25ºC to +40ºC
Electrical
- Input Voltage***: 90 – 250VAC, 50/60 Hz
- Power Supply: Modular Internal Switching
- A/C Current: 15A @ 220V for Full Power.
Connections
- Power (See Electrical)
- A and B Drive
- A and B Output
- A and B -60dBc Sample Port
- A and B PTT In
- A and B PTT Out
- A and B CAT
- A and B CI-V
- A and B Band Data IN
- LAN connection
Build Your Station.
Visit our Learning Center
Need help with our products, software or services? Start by visiting our learning center. Once there, you can download data sheets, quick start guides, installation manuals and watch video tutorials.
*SmartLink Remote Requires SmartSDR V2.x License. Requires internet connection. May be subject to country specific laws and regulations.
** SO2R Configuration *** Maximum RF power output achieved using 220 VAC
