Compact Desktop 40A|13.8V Power Supply by RigExpert
- Rated power: 500W
- Rated current: 40A
- Output voltage: 12.5-15 V
- Input voltage range: 80V to 264V
- Input frequency range: 47 Hz to 63 Hz
- Working temperature range: -30°C to +70°C
- Acoustic noise: ~21 dBa
- Overvoltage protection: Yes
- Overcurrent protection: Yes
- Short circuit protection: Yes
- AC current: 5,. А @ 110 VAC | 2.9 А @ 230 VAC
- EMC Emission: Class I: Class B, Class II: Class A
- EMI noise: 200mVp-p
- Storage temperature range: -40°C to +85°C / -40°F to +185°F
- Energy Conversion Efficiency (ECE): > 90% (Heat dissipation at maximum load < 60 W)
- Ports on the front panel
- 2 x 3A USB A Charging Ports
- 2 x 3A USB Type-C Charging Ports
- 2 x 45A Anderson Power Poles
- Ports on the rear panel
- 1 x 30A Binding Post
- 1 x 45A Anderson Power Pole
- 1 x USB Type-C for PC Communication
- Dimensions: 172 mm x 55 mm x 185 mm
- Weight: 1.1 kg
Warranty: Manufacturer’s 2-year limited warranty coverage
