This rugged industrial grade all metal PTT foot switch with a 7 foot fiber reinforced cable and RCA phono plug is truly intended for industrial manufacturing floor use and the construction is there to support this sort of heavy-duty use. It features a powder coated finish, rubber non-slip pedal and foam rubber cushion on the bottom to prevent wandering under your operating position. It is just what you’ve been looking for for that DX or Contest or Net Control Station. Can be used with any radio that has an RCA jack for PTT (all except the FLEX-1500)
