A backup SD card for your FLEX-6000 Series Transceiver.Â
This card is installed internally on your radio and it does require you to remove the covers of the radio (#8 Torx).  Some internal disassembly of models 6300, 6500 and 6700 is required to access the SD card as the card holder is under an RF shield within the radio.
- Do not order this card if you are unsure of your ability to physically replace the card on your radioÂ
- The card that is sent to you is specifically for your radio and is not to be shared
- Cards will be shipped with the most current version of Version (or higher)
- Your Radio model number and Radio Serial number are required when ordering
The card should only be installed in your radio if advised by our technical support team. Â
If your radio is in a failing state, open a HelpDesk Ticket so that we can diagnose your issue.
FLEX-6300 SD Card Replacement Procedure
FLEX-6700 and FLEX-6500 SD Card Replacement Procedure
FLEX-6600(M) and FLEX-6400(M) SD Card Replacement Procedure
There are no refunds on Software or SD Cards.
