Commercial High Frequency (HF) 10kW Linear Power Amplifier
$319,860.00
The FPA-10K HF power amplifier from FlexRadio, Inc. is the perfect choice for reliable and efficient HF communications for voice and data. This power amplifier has been designed to provide continuous coverage of HF frequencies at sustained power levels and is rated for 100% continuous operation in all HF modes. The amplifier is easy to configure and monitor using a secure, simple web interface with fault-reporting features and visible external LEDs. Advanced switch-mode power supplies maximize efficiency and reduce heat, while the amplifier’s LDMOS devices are protected against detrimental load conditions and excessive heat sink temperatures. The amplifier also features intuitive, user-friendly operation and easy maintenance procedures that make it affordable. The FPA-10K HF power amplifier from FlexRadio, Inc. is the ideal choice for reliable and efficient HF communications for voice and data. With its advanced features and safe operation, you can be sure it will provide years of reliable performance
