AU-520M Dual-SCU 500W Integrated SDR Transceiver with Maestro Front Panel
The AU-520M combines the power of a high-performance dual-SCU SDR with the convenience of an integrated Maestro™ front panel—offering unmatched versatility for operators who demand both flexibility and control.
Inside its compact chassis, the AU-520M integrates a full-featured software-defined transceiver, a high-efficiency 500W amplifier, an automatic antenna tuner, and a wide-range AC power supply—delivering serious performance without the need for external components.
At its core is a state-of-the-art transmitter module capable of up to 500W PEP at up to 90% efficiency, significantly reducing heat, power consumption, and physical size. The built-in Maestro front panel gives you instant touchscreen access, with responsive knobs and buttons for an intuitive, stand-alone operating experience—no PC required. Radios are licensed for SmartSDR Basic.
The AU-520M features two independent SCUs (Spectral Capture Units), each capable of simultaneously digitizing wide portions of the spectrum. This allows for up to 4 slice receivers and 4 independent panadapters, giving you true multi-band visibility and operation—covering 30 kHz to 54 MHz in real time.
