Aurora series models
Back to Signature series models
Aurora Model Comparison
Need help building your station?
Contact us
Recommended that you rotate screen sideways to view in landscape for mobile.
FlexRadio Flex-AU-510
FLEX AU-510
FlexRadio Flex-AU-510M
FLEX AU-510M
FlexRadio Flex-AU-520
FLEX AU-520
FlexRadio Flex-AU-520M
FLEX AU-520M
MSRP $6,199.00 $7,349.00 $8,599.00 $9,599.00
Transmitter Power 1–500W HF, 1–200W 6m 1–500W HF, 1–200W 6m 1–500W HF, 1–200W 6m 1–500W HF, 1–200W 6m
Efficiency (Peak) Up to 80% Up to 80% Up to 80% Up to 80%
Spectral Capture Units (SCUs) 1 1 2 2
Slice Receivers / Panadapters 2/2 2/2 4/4 4/4
RX Antenna Ports 1 1 2 2
Transverter Ports
(0 – +10dBm)
1 1 2 2
Frequency Coverage 30kHz–54MHz 30kHz–54MHz 30kHz–54MHz 30kHz–54MHz
Full Duplex
Display x 8″ 1920×1200 IPS Touchscreen x 8″ 1920×1200 IPS Touchscreen
Maestro Front Panel x x
Integrated HDMI Output x x
SmartSignal™ (Adaptive
CESSB (RF Compression)
MultiFlex™ (Dual Client Support)
Integrated Tuner
Integrated Power Supply
Remote Operation (SmartLink™)
External Display Support (HDMI®) x x
GNSS / GPSDO Support ✓ / Optional ✓ / Optional ✓ / Optional ✓ / Optional
SO2R Ready x x
Power Input 80–264VAC 80–264VAC 80–264VAC 80–264VAC
Dimensions (H × W × D) 6.74″ × 14″ × 13.25″ 6.74″ × 14″ × 13.25″ 6.74″ × 14″ × 13.25″ 6.74″ × 14″ × 13.25″
Accept
