4O3A Antenna Genius 8×2 Antenna Switch
Ports: DC power, RJ-45 (100-Mbps Ethernet), 2 x 15-pin DE-15 socket (VGA style)
Power Consumption: 13.8-VDC @ 300mA
Controlled by: FlexRadio, 4O3A Interface Genius, BCD or Pin To Port
Weight: 5.5-lbs (2.5-kg)
Dimensions (HWD): 10.6″ x 6.7″ x 2.8″ (27cm x 17cm x 7cm
The Antenna Genius operation manual is available here.
Note:  RF on 6M / 50Mhz needs to be limited to 800 watts for Constant Carrier Modes such as FT8, RTTY, etc.
