Introducing Maestro™ — an intuitive, plug-and-play control console that directs operation of any FLEX-6000 Signature Series transceiver without need of a traditional PC. Connect Maestro directly or through your local area network (LAN) to any FLEX-6300, FLEX-6500, or FLEX-6700 transceiver and you are ready to operate.
Maestro places the most frequently used controls directly at your fingertips. Controls are labeled for intuitive operation and designed to minimize hand motion for the most common operations. Occasionally used controls are easily accessible on the large touch screen display bypassing the complexity of multi-function buttons and multi-level menus found on most transceivers. Like modern phones and tablets, capacitive touch control is provided on the large LCD display for intuitive pan, zoom, tune, and menu operation.
For more technical information on Maestro, just download the Maestro Product Brochure or visit the Maestro product web page.
Radio in High Resolution
Never miss a signal
  • 8” High Definition (WXGA 1280 x 800)
  • Multi-touch
  • High Resolution Panadapter and Waterfall
  • Large, Easy-to-read Text
Specs
  • Weight: 96 oz
  • Width: 7 in
  • Depth: 14 in
  • Height: 3 in
Communications Interfaces
  • Wi-Fi: Dual band 2×2 802.11a/b/g/n
  • Ethernet: 10/100/1000 Mbps
 Mechanical
  • Without Feet:
    Height: 6.75″ (17.1cm)
    Width: 14″ (35.6cm)
    Depth: 1.75″ (4.5cm)
  • Weight: Approximately 4 lbs. (1.8 kgs)
 Electrical
  • Power: 10-15 VDC
  • Standard wall mount AC adapter
  • Battery: Optional Lithium-ion battery**
 Display/Touch Screen
  • Up to 2 simultaneous, real-time spectrum displays and waterfalls
  • Dual VFO Readouts
  • Display Type: Large 8.0″ In Plane Switching (IPS) display with touch screen
  • Display Resolution: HD (WXGA 1280 x 800) display resolution
  • Tilt hinge feet (constant torque)
  • FlexRadio FHM-2 hand mic
  • Soft-side carry case
  • Plastic dust cover
 Input/Output
  • Microphone 1: Pseudo-balanced 8-pin RJ-45, dynamic or electret compatible
  • Microphone 2: Pseudo-balanced 1/8″ (3.5mm) TRS
  • Headphones: Stereo headphone jack, 1/8″ (3.5mm) TRS
  • Headphones Impedance: 16 Ohm at 25 mW, 32 Ohms at 13 mW with THD+N: 0.02%
  • Speaker: Internal 2W mono speaker
  • Powered Speaker Output: Stereo consumer line level or powered speaker output, 1/8″ (3.5mm) TRS
  • Line Output: Stereo consumer line level or powered speaker output, 1/8″ (3.5mm) TRS
  • Line Out/Powered Speaker Output Impedance: 600 Ohm, stereo unbalanced
  • Line Input: Pseudo-balanced line-in jack, 1/8″ (3.5mm) TRS
  • Key/Paddle Input: 1/8″ (3.5mm) TRS
  • PTT Input: 1/8″ (3.5mm) TS
  • DC Power Connector: Coaxial DC power connector, 2.1mm (cable included)
Radio Anytime, Anywhere
With SmartLink remote*, just turn it on and play radio from anywhere.
  • Plug and Play Remote
  • Built in Wi-fi and Ethernet
  • Truly Wireless Operation**
Confusion Free Controls
Only the controls you need, only when you need them.
  • Ergonomic
  • Single Function
  • Wide Spacing
  • Intuitive Touch Screen Menus
  • Illuminated Buttons
  • Two full VFOs
*SmartLink Remote Requires SmartSDR V2.x License. Requires internet connection. **Requires customer supplied battery.
FlexRadio Systems does not charge your credit card until your order ships, but we do pre-authorize the the full purchase price at the time you place your on-line order. If you choose to use PayPal as your payment method, your account will be charged immediately.
Due to the price class of a Maestro Control Console, your order may exceed your credit card’s daily transaction limit resulting in your order not being completed. In these cases, you may either contact your credit card company and negotiate a different daily purchase limit -OR- you can call FlexRadio Systems Sales department at 512-535-4713 ext 1 to place your order over the phone where we will not pre-authorize order payment until time of shipment.
