Certified Pre-Loved FLEX-6400 radios are sold in excellent condition with a one year warranty. They have been through a full factory test and recalibration.
HF/50 MHz Direct Sampling Software Defined Radio Transceiver
The FLEX-6400 with Automatic Antenna Tuning offers the latest direct sampling SDR technology at an economical price for the general HF/6m operator yet they offer great performance for chasing DX and contesting. The FLEX-6400 model is designed for the Ham who wants to operate the radio exclusively as a server from PC, laptop, Maestro, Mac, or iOS clients — whether local or remote. Both models share the same game changing band awareness, industry leading phase noise performance, brick wall filters, and legendary audio performance to deliver you the most fun across a wide variety of operating styles.
With a PC, laptop, or Mac client you can utilize up to two 7 MHz spectrum/waterfall displays and independent receivers to revolutionize your view of the bands. Its two receivers can be placed simultaneously on any band and mode with instant QSY between VFOs. Digital mode operation is a dream with no sound cards, cables or boxes needed.
FlexRadio’s industry leading SmartSDRâ„¢ software offers compatibility across the entire FLEX-6000 Signature Series family to deliver continuous leveraged software enhancement. And you can use the latest SmartLinkâ„¢ technology to access your radio virtually anywhere from any SmartSDR compatible client with only a login and password — even your iPhone.
  • 100W PEP HF-6m operation
  • All modes/all bands
  • Integrated Remote Operation with Maestro, PC/ Laptop, iPad® or iPhone®
  • Transverter Port
  • Receive-Only Port
  • Direct Sampling SDR 122.88 Msps – 16 bit
  • 115 dB 2kHz RMDR
  • 10 MHz Reference Input with GPSDO option
  • Optional MARS/CAP/SHARES Expansion
  • Optional Antenna Tuner
Specs
  • Weight: 256 oz
  • Width: 18 in
  • Depth: 19 in
  • Height: 12 in
Receiver
  • Receive Only Ports (Base/Including XVTR Port): 1/2
  • Full Duplex RX/TX Operation
 Spectrum/Waterfall
  • Internal Touch Panel Display Size Diagonal: 8-inch (6400M)
  • Integrated Display Resolution: 1920×1200 (6400M)
  • External Display Resolution/Connection: 1920×1200/HDMI (6400M)
  • Spectrum/Waterfall Displays (Max): 2
  • Spectrum/Waterfall BW (Min/Max): 5 kHz to 7MHz
  • Spectrum Resolution Bandwidth (Min): 5.85 Hz/px
 Transmitter
  • Transverter Ports: 1
  • (OPTIONAL) Integrated Automatic Antenna Tuner Range: 3:1 SWR
  • Continuous MARS/CAP Coverage with Optional Filter
 General
  • Modes (Note 1) SSB, CW, AM, SAM, FM, FREE-DV, RTTY, DIGITAL
  • Maestro, PC, MAC, iPhone, & iPad Client Options
  • Internal Speaker/Power 2W Class D (6400M)
  • Frequency Stability (0C – 50C) 0.5ppm (TCXO)
  • GPS Disciplined Oscillator Optional 5 x 10-12 Over 24 Hours
  • Power Supply Requirements 13.8 VCDC +/- 15% (14 VDC Nom)
  • Dimensions 6.74″H (17.1 cm) x 14″W (35.6 cm) x 13.25″D (33.7 cm)
Simply Beautiful
  • No PC required to operate the FLEX-6400M*
  • 8 inch 1920 x 1200 IPS Display
  • Up to two independent receivers
  • Up to two 7MHz spectrum displays
  • Ergonomic workflow
  • Widely spaced / single function controls
Plug & Play Remote**
  • No complex setup required
  • Operate anywhere, any time
  • Use a Maestro, iPad, iPhone or Laptop
  • Complete control
With SmartLink and a FLEX-6400/FLEX-6400M you can operate your radio from almost anywhere! Just take an iPhone, iPad, Laptop or Maestro with you and instantly connect to your radio with virtually no setup required.
Best in Class Performance
  • 115db RMDR
  • No noise fatigue
  • Ultra Low Phase Noise
  • Full Break-in QSK CW
  • Brick Wall Filters
  • Stunning transmit audio
*A PC may be required for use of 3rd party software such as loggers and digital modes programs. **SmartLink Remote Requires SmartSDR V2.x License. Requires internet connection. 1. RTTY and other digital modes use 3rd party software over DAX channels.
FlexRadio Systems does not charge your credit card until your order ships, but we do pre-authorize the the full purchase price at the time you place your on-line order. If you choose to use PayPal as your payment method, your account will be charged immediately.
Due to the price class of a FLEX-6000, your order may exceed your credit card’s daily transaction limit resulting in your order not being completed. In these cases, you may either contact your credit card company and negotiate a different daily purchase limit -OR- you can call FlexRadio Systems Sales department at 512-535-4713 ext 1 to place your order over the phone where we will not pre-authorize order payment until time of shipment.
